Bike Extensions Wiki
This is a wiki post meaning anyone can edit it.
Use this wiki to link to posts about Bike workflows and scripts. If you have something to share please make a post and then link to it from this page to make it easy for others to find your post in the future.
Documentation
Scripts
  • Home – Reset your outline to “home” state
  • Cleanup – Collapse everything except what’s needed to show current selection.
  • Today – Create a simple calendar structure for todays date.
  • Thesaurus – Generate list of synonym from current word
  • Paste to Mail – Bike Outline to Mail.app indented text
  • Focus Beam – Move focus to sibling of current focus
  • Block Travel – Move to next visible empty line
  • Markdown to Bike – Ruby script markdown lists to Bike outline
Shortcuts
Shortcuts to use with Bike 1.11 or later on macOS 13 or later:
  • Shortcuts Tutorial including shortcuts to Cleanup, Save Tabs, Show Matches, and Today.
  • Move to ancestor – Move selection to current rows to ancestor row
  • Document Hub – Create links from a “hub” document to new documents. A way to create a “document library” style interaction for Bike.
