Bike may at some point acquire row type attributes like note
etc, and a style-sheet mechanism for making row type differences visible, but in the meanwhile:
here is a script for toggling single character prefixes( like >
, for example) at the start of each selected line:
To test in Script Editor.app
- set the language selector at top left to JavaScript (rather than AppleScript)
- copy and past the whole of the script behind the expansion triangle below,
- select some lines in Bike
- and click Run.
"use strict";
// Toggle a given prefix character in selected lines
// of Bike 1.2
// Rob Trew @2022
// Ver 0.01
// --------------------- OPTION ----------------------
// Which single-character prefix to add or clear ?
const prefixChar = ">";
// const
// prefixChar = Application("Keyboard Maestro Engine")
// .getvariable("local_PrefixChar");
// ------------ PREFIX CHARACTER TOGGLED -------------
// main :: IO ()
const main = () => {
bike = Application("Bike"),
doc = bike.documents.at(0);
selectedRows = doc.rows.where({
selected: true
n = selectedRows.length;
return Boolean(n) ? (() => {
const [f, change] = (
selectedRows.at(0).name()
.startsWith(prefixChar)
[dePrefixed(prefixChar), "CLEARED"]
) : [prefixed(prefixChar), "ADDED"];
zipWith(row => s => row.name = s)(
selectedRows()
selectedRows.name().map(f)
`${change} '${prefixChar}' prefix`,
`in ${n} selected lines.`
.join("\n")
})() : "No rows selected in Bike";
// -------------------- PREFIXES ---------------------
// prefixed :: Char -> String -> String
const prefixed = c =>
s => `${c} ${dePrefixed(c)(s)}`;
// dePrefixed :: Char -> String -> String
const dePrefixed = c =>
s => c === s[0] ? (
s.slice(" " === s[1] ? 2 : 1)
) : s;
const zipWith = f =>
// A list constructed by zipping with a
// custom function, rather than with the
// default tuple constructor.
xs => ys => xs.map(
(x, i) => f(x)(ys[i])
).slice(
0, Math.min(xs.length, ys.length)
// MAIN
(You can choose a different single-character prefix by editing the value of the prefixChar
string constant at the top of the script)
Keyboard Maestro makes it easier to:
- bind keystrokes to scripts like this, and
- adjust options (e.g. here, make different copies for different prefixes)
- get feedback in notifications
BIKE :: Toggle a prefix character in selected lines – Keyboard Maestro Macro
