This script copies the selected rows in Bike into a CSV format on the pasteboard.
To test in Script Editor.app,
- set the language selector at top left to JavaScript (rather than AppleScript)
- copy and past the whole of the script behind the expansion triangle below,
- select some lines in Bike
- and click Run.
var bikeApp = Application("Bike")
bikeApp.includeStandardAdditions = true
var document = bikeApp.documents.at(0)
var zip = (a, b) => a.map((k, i) => [k, b[i]])
var ancestors = []
var results = []
var selectedRows = document.rows.where({selected: true})()
for (each of selectedRows) {
const eachLevel = each.level()
while (ancestors.length > 0 && ancestors[ancestors.length - 1].level() >= eachLevel) {
ancestors.pop()
ancestors.push(each)
if (!each.containsRows()) {
let line = []
for (eachAncestor of ancestors) {
let eachName = eachAncestor.name()
let eachEscapedName = eachName.replace(/"/g, '""')
line.push('"' + eachEscapedName + '"')
results.push(line.join())
bikeApp.setTheClipboardTo(results.join('\n'))
results
Using Scripts - Bike
and a minor variant for a slightly different context – CSV for the full path to each selected row that is:
- not empty, and
- either childless or collapsed
"use strict";
// Ver 0.03
// CSV of full path to each leaf or collapsed row
// that is selected.
// Returned and copied to clipboard.
const main = () => {
csvLeafPaths = selectedUILeaves(doc)
.map(csvOfFullRowPath)
.join("\n");
Object.assign(
Application.currentApplication(),
{includeStandardAdditions: true}
.setTheClipboardTo(csvLeafPaths),
csvLeafPaths
})() : "No documents open in Bike.";
// --------------------- BIKE ---------------------
// csvOfFullRowPath :: Row -> CSV String
const csvOfFullRowPath = row =>
pathToRow(row)
.slice(1)
.map(x => `"${x.name().replace(/"/ug, "\"\"")}"`)
.join(",");
// pathToRow :: Bike Row -> [Bike Row]
const pathToRow = row => {
// Ancestral path from root row to given row.
go = x => null !== x
? [...go(x.containerRow()), x]
return go(row);
// selectedUILeaves :: Bike Document -> IO [Row]
const selectedUILeaves = doc =>
// Rows in the selection which not empty
// and are either leaves or collapsed parents.
doc.rows.where({
selected: true,
_not: [{name: ""}],
_or: [
{containsRows: false},
{collapsed: true}
// MAIN ---
( testing and use as above )
