You will find some earlier discussion of progress towards QuickLook support here:
Quicklook support
To copy a Bike document (or just selected rows, if the selection is extended) as a bulleted plain text (tab-indented) outline, there is a Keyboard Maestro macro here:
BIKE Outliner - Copy as Bulleted Plain Text - Keyboard Maestro Discourse
and if you don’t use Keyboard Maestro, you can also use something like FastScripts to bind a keystroke to the Copy as Bulleted Plain Text script below:
"use strict";
ObjC.import("AppKit");
// Copy Bike document
// (or Bike selected rows, if selected is extended)
// as bulleted plain text.
// RobTrew @2022
// Ver 0.01
// main :: IO ()
const main = () => {
return doc.exists() ? (
copyText(
bulletedTextFromBikeDoc(doc)
) : "No document open in Bike";
// ---------------------- BIKE -----------------------
// bulletedTextFromBikeDoc :: Bike Doc -> IO String
const bulletedTextFromBikeDoc = doc => {
rows = Boolean(doc.selectedText()) ? (
doc.rows.where({selected: true})
) : doc.rows;
return bulletOutlineFromForest(
forestFromIndentedLines(
zip(
rows.level()
rows.name()
const copyText = s => {
pb.clearContents,
pb.setStringForType(
$(s),
$.NSPasteboardTypeString
s
const Node = v =>
// more child trees.
xs => ({
type: "Node",
root: v,
nest: xs || []
const Tuple = a =>
// different types.
b => ({
type: "Tuple",
"0": a,
"1": b,
length: 2,
*[Symbol.iterator]() {
for (const k in this) {
if (!isNaN(k)) {
yield this[k];
// bulletOutlineFromForest :: Forest String -> String
const bulletOutlineFromForest = trees => {
const go = tabs => tree => {
const txt = tree.root.text;
return [
Boolean(txt) ? (
`${tabs}- ${txt}`
) : `${tabs}`,
...tree.nest.flatMap(go(`\t${tabs}`))
return trees.flatMap(go("")).join("\n");
// forestFromIndentedLines :: [(Int, String)] ->
// [Tree {text:String, body:Int}]
const forestFromIndentedLines = tuples => {
const go = xs =>
0 < xs.length ? (() => {
// First line and its sub-tree,
const [depth, body] = xs[0],
[tree, rest] = span(x => depth < x[0])(
xs.slice(1)
return [
Node({
text: body,
level: depth
})(go(tree))
// followed by the rest.
.concat(go(rest));
return go(tuples);
// span :: (a -> Bool) -> [a] -> ([a], [a])
const span = p =>
// Longest prefix of xs consisting of elements which
// all satisfy p, tupled with the remainder of xs.
xs => {
const i = xs.findIndex(x => !p(x));
return -1 !== i ? (
Tuple(xs.slice(0, i))(
xs.slice(i)
) : Tuple(xs)([]);
// zip :: [a] -> [b] -> [(a, b)]
const zip = xs =>
// The paired members of xs and ys, up to
// the length of the shorter of the two lists.
ys => Array.from({
length: Math.min(xs.length, ys.length)
}, (_, i) => [xs[i], ys[i]]);
If you test the script in Script Editor.app, (making sure, of course, to copy the whole of it, scrolling right down to the bottom), you will need to set the language selector at top left to JavaScript rather than AppleScript.
See: Using Scripts - Bike
