Hanging Indents (or other suggestions for cleanly theming multi-line notes)
I’m looking for an innocuous way to have multiple notes in sequence visibly distinct from one another. My preference would be to have a hanging indent but my attempts at this using
text-indent: -28px;
padding-left: 28px;
haven’t worked. I read elsewhere that you can’t do this in FoldingText so I’m guessing maybe it’s the same in TP themes.
What I’ve done for a stop-gap is to color the handle for notes (handles are otherwise invisible in my theme) but I’d prefer the clean look of a hanging indent…any hope? The biggest annoyance with coloring handles is that if I have a stray newline anywhere I get a random floating handle with nothing next to it.
The daytime theme if anyone wants to take a look is at: https://gist.github.com/derickfay/bd183eb697c0dd4ef0b4a1bcb419eddf
And the nighttime theme: https://gist.github.com/derickfay/57c82403080fca04dd9a22555c41c306
TaskPaper theming syntax is the same as CSS, but the themeable attributes are a small subset. There is no support for text indent or anything similar. More info can be found here.
You can fix that with this rule:
item[empty] {
  handle-color: none;
  handle-border-color: none;
Also thanks for posting your themes. If you want you can also add links to this page:
Thanks for the quick reply & advice - I’ve added the links to the wiki.
