Feature Request: Always-on-top Window option
I already do use TaskPaper for a multitude of todo lists, it really would be amazing if there were an option to float a particular window on top, so I could have a small taskpaper of open/high priority tasks always on top or perhaps with a configurable level of transparency when it doesn’t have focus. This would be an amazing feature for my work. In the mean time I’ll throw it on screen #4 and see if I use it or forget about it way over there in dashboard land. Thank you for an amazing product!
I’m not sure when/if I’ll add this. But I know that there are some scripts / integrations with other apps, to achieve this sort of thing, by placing tasks in the menu bar. Unfortunately I forget the exact place that I saw the script. It might be added to:
It was posted fairly recently I think… anybody remember or have a link to what I’m talking about?
Thanks Jesse, I’ll do some wiki digging. I tried a couple utilities, Deskovery might show some promise if I disable 90% of what it’s intended for. I need to disable SIP and install its advanced features helper to really see.
Can this Always On Top feature be added? All these afloat and other utilities that enable Always On Top no longer work since catalina mac release, and now we have Sequoria, this important feature still lacking. Can you add this support in your application rather than rely on utilities (if there is any yet).
thank
Does Window → Float on top not work for you?
Yes, noted. That’s work. thank
