Changing text of @done to @achieved
Is it possible to change the @done tag so that the text reads @achieved (while still having the same functionality), or is that hard coded in the app?
Thanks.
The toggle done menu item is hard coded into the app.
You could recreate much of the functionally with custom AppleScripts and assign keyboard shortcuts to them. Might be more work than worth, but if you really wanted to.
You could get a start here:
Search for “toggle” for scripts that toggle tags.
Search for “archive” for scripts that archive.
Jesse
Thanks Jesse, for the reply and the app. I figured it would be a scripting solution.
