Runs on macOS 15.6. WriteRoom 4 now runs on macOS Sequoia 15.6 and later.
Folding and moving. Edit ▸ Fold and Edit ▸ Arrange now use Bike’s commands and shortcuts.
Word (.docx) export. File ▸ Export ▸ Word Document and Edit ▸ Copy ▸ Word Document export and copy Word-formatted text.
More per-window settings. The Settings window still sets the defaults. Use View ▸ Theme and Line Width to change just the front window.
Clean Up Markdown. Format ▸ Clean Up Markdown… rewrites the selection or whole document in standard Markdown formatting. Format ▸ Check Document… lists broken links and other problems.
Performance. I’ve spent much of this release with a giant, 1 GB Markdown file open. It’s fast now, so your documents should be too!
Accessibility. VoiceOver, Zoom, Voice Control and other assistive apps can now access the editor.
Added Solarized Dark and Solarized Light themes
Added Edit ▸ Selection with Expand Selection (⌃⇧⌘→)
Added heading numbers (Settings ▸ Markdown ▸ Live Preview)
Added Rename Heading, which updates links to the heading
Added Renumber List and improved automatic list renumbering
Added Move Column, Sort Rows and Convert to Table
Added Go to Definition (⌃⌘J) and Previous/Next Link
Added pandoc definition list syntax
Added superscripts and subscripts (4^th^, H~2~O)
Added footnotes that fold and hold indented paragraphs
Added emacs keys: ⌃K kill, ⌃Y yank, ⌃T transpose
Added encoding and line ending conversion to Document Info
Added Edit ▸ Copy ▸ Link to Heading
Added option to check parent and subtasks together
Changed View menu settings to affect only the front window
Changed Mark as Done to Mark as Completed (⇧⌘C)
Changed Split Editor to ⌃⌘S
Changed heading overview from held Escape to ⌥⌘O
Changed Actual Size to ⇧⌘0 and Inline Code to ⇧⌘M
Changed Return to autocorrect the word before it, like Space
Fixed spelling marks waiting for the next edit to appear
Fixed autocorrect capitals after footnotes and markup
I’m looking at this release as close to final. So please note any remaining rough points. Guide update still to go. Also I have texted 15.6 in VM, curious to know if it works well in real install.
EDIT: Also, seems a little weird how Writeroom indents - Four less than - Three, according to the RAW file shown below (I indents are via TAB, not spaces) → Probably because headings have a different margin?
Each theme is independent, they just decide which syntax to style. But I agree the Solarized needs adjustments. I’m going to copy VIM solarized theme more closely.
