Changes include:
Added “poof” animation for menu Item > Delete Items
Select existing tab (if exists) when selected item in sidebar
Command click file link to reveal the file in Finder instead of open
Changed format to ignore seldom used task start chars + and *.
Fixed indentation of Home item in Sidebar
Please try it out and let me know if you see any problems.
Download
Just posted a new version of this preview that adds back old “poof” animation when deleting items. Pref to disable.
Posted a new version that only recognizes - as leading char for task lines.
Posted new version that fixed issue raised in this post:
Hi.
apologies if I was unclear.
I am not creating a new document. I am combining two existing documents already populated with content.
drag & drop title bar of A onto title bar B to create new tab. Or or Merge All Windows
focus on project in B
click on home in sidebar
A comes into the foreground. Not defocused B
focus on project in A
return to B
click home in sidebar
8 B is defocused
return to A
B is brought to the foreground.
Best
ros
In this version the UI is updated for macOS Big Sur … when running on Big Sur titlebar is transparent. Now actually looks almost exactly like the first mockup in this post from 2016:
Here are two more mockups that I was experimenting with:
[image]
[image]
They work a bit better with narrow window sizes since the search text doesn’t compete with the title text. These were the mockups that I started with, then think I stared at them to long and so found my previous posted markup appealing and called that my favorite. Now that I’ve stared at that one for a while… these look more appealing again
Anyway, thoughts welcome!
Not sure that I’m fully on board… the reason I ended up not going with that approach is because in the end I like a clean distinct toolbar better. But I guess this is the future, so I’m going with it!
