I was wondering if there is (or could be) a way to “paste as attachment” when the clipboard contains a file (eg. copied from Finder, or put there by some other process). Right now this case pastes as a file path, and I don’t know of a way to attach the file instead. It looks like the Attachments API is read-only so it doesn’t seem possible to add a keyboard shortcut (eg. Shift+Cmd+V) from the outside.
Yes! And sorry I think you mentioned this before, and I saw it, but then forgot about it.
Thank you! And no worries at all, wasn’t sure if I should have made a thread in the first place since it was a separate topic.
Should be fixed in Bike 2.0 (Preview 305)
ooh that’s great. thank you!
