fssbob
April 28, 2024, 3:58am
1
After using Apple’s migration program to migrate to a new Mac, I’m continually receiving the message " Paddle: UUID not matched ". How do I fix this? Thanks.
I think the fix is detailed here:
This error is coming from the Paddle license key system. I think if you go to Bike’s Preferences > License and then:
Copy your existing license key
Deactive your license
Paste in that saved license key and Activate your license
It should go away.
and perhaps more recently:
I was seeing crashes using the latest Paddle framework, so I downgraded in the 1.7.2 release, I think maybe that’s causing this. Anyway I think you can fix by:
Go to Bike’s Preferences > License and then:
Deactivate your license
That worked once in the past when this issue came up, please let me know how it goes this time.
