I’m currently using Bike Outliner 2.0 as my main note-taking and outlining app, and I would really like to use Cotypist together with it.
However, Cotypist does not seem to work inside Bike. I’m not sure whether this is caused by Bike, Cotypist, macOS text input behavior, accessibility permissions, or something in my own setup.
Since I type a lot every day in Bike, having Cotypist work there would be extremely helpful for my workflow.
Has anyone here tried using Cotypist with Bike Outliner 2.0? If so, did it work for you? Are there any settings, permissions, or workarounds that I should check?
I’d really appreciate any guidance from the community.
