I don’t think I’m quite ready for tags. To be really useful I need to filter outline based on them, and to do that I need to decide and implement query language.
I think the next big feature that I’ll tackle is row types, so headings, separators. Maybe also different list types and tasks.
Right now I’m trying to decide if I should start that or if I should do a release of bug fixes and smaller features. I also have a bunch of Shortcuts code that I’ve written, but need to finish up and integrate into app.
OK, I confess I didn’t have time to test things in the Preview version. But in the released version: When I go to print the first time after opening a document, everything works fine–including using focus. However, subsequent attempts to print almost always result in only the top outline level in the current view printing. To get expected printing behavior, I have to first close and then reopen the document.
Given the above outline are you saying if you zoom into “two” then print then “five” won’t print? Note that printing takes collapsed state into account, are you sure items just aren’t collapse?
