I’ve been using Bike 2 pretty heavily for the past few days. Timesink.app says it’s been 10 hours and 55 minutes spent with the app window focused in November workdays. I’ve mostly been working on an outline document that has now reached 30.000 words in total. That means I have some thoughts ![]()
Overall, the app feels smooth and lightning fast, just like I’m used to from Bike 1.x. Painfully, there are some features still missing for quick travel (like Focus heading), but the new filtering system is great for raking out the big picture. This is fantastic work.
There were a few things that frustrated me:
- Current
Move upandMove downoutline movements don’t make sense to me, as I’ve noted here. I’ve accepted that Bike is block-based now, but the two distinct modes of operation of Bike 1.x made for much more predicability in outline movements. In this iteration, I’m never sure where parts of my outline will end up and what I’ll end up displacing. - I frequently missed the
Expand/collapse alloption from Bike 1.x. At this point, I’m not sure what I have to do to explode the outline fully. It seems I can select all and hitExpand roworExpand Row by Level(both seem to achieve same result), but once the outline expands beyond the current window limits, I’m never sure how many times I still need to hit to cover everything. - I’m still not sold on the
⌘+0/9to expand/collapse single row, especially when in block mode. When I navigate the outline, I use the arrow keys. Using←/→in block mode and⌘+⬆/⬇in edit mode feels much more natural for my fingers. I know this is something that can be changed via custom keybindings but that requires extra coding, and it doesn’t come without conflicts, as I noted here. - Finally, the biggest part—data portability.
.bikemdis a great addition to the toolset, and it plays reasonably well with other markdown editors, up until they encounter[pandoc]{syntax}. Unfortunately, there doesn’t seem to be a good .md editor on the market that’s able to reproduce these tags faithfully. I can edit, yes, but I can’t use without significant cleanup. The idea of having to learn pandoc as yet another tool that works exclusively in the macOS Terminal with a custom script to recognise highlights before I can push an outline to a dedicated writing app is something just doesn’t sit right with me. I think long-term aPublish...→ RTF, MD, TXT, DOCX, PDF etc. that will produce nicely formatted, clean results is a must-have addition.
This may sound harsh, but I really love using Bike. I think it’s insanely brilliant and even more powerful. It’s an incredible tool to have and I’m thankful to Jesse for creating it. I probably couldn’t handle my books without it. I’d like to use it everywhere, especially on iPad. Right now, #4 is the bottleneck for my workflow. I really hope this gets solved.
