This new version does not let me save (or autosave).
I restarted my mac and reinstalled the same version, but without success. I’ve had to go back to an older version. Any ideas?
Weird. I have no problem with Bike 1.4, 69. On an iMac (2017), OS 12.4
Also works fine on my M1 MBA, OS 12.4
Thanks. I’m running MacOS 12.5 on a MacBook Pro 2021 (M1 Pro chip)
Does it show an error dialogue?
And what happens if you:
I’m experiencing this inability to save if I try to save the Bike file as plain text (or .md).
See post above.
@hooley @TrapezeArtist Thanks I think I’ve fixed this for the next release. I hope to get that fix (and other updates out) by this Friday.
Thanks @jessegrosjean I just returned from a week off and am also having the issue. On an M1 machine.
@jessegrosjean I don’t know if this information helps you but i had this saving issue with version 68 and 69. I had the roll back to 67.
Thanks for letting me know. I “think” this is fixed for next preview release, but that will still take a bit to arive.
sounds good. I’m running fine on 67 for my needs.
I think this is fixed in: Bike 1.4 Preview (70) “Rich Text”
thanks, Jesse. So far so good.
