Fixed pasting Hookmark links into plain text outline
To get preview releases through Bike’s software update select: Bike > Preferences > General > Include “preview” releases. Or download directly from Bike’s releases page:
I found that “auto-name ‘Untitled’ documents based on first sentence” feature doesn’t work after this update. I have attach a screen recording (.gif) for your reference. (Bike 1.18.1 Preview (172), macOS Sonoma 14.4)
Good catch, thanks. Apparently now that iCloud Documents is enabled there’s a different code path for saving which broke this. It seems I can mostly fix, but not completely. The difference after my partial fix will be:
In old implementation the title would change until you finally manually saved.
In new documents iCloud implementation the title only updates until first autosave.
I liked old behavior better, but I don’t see any way to solve, most of NSDocument is a black box and I just have to go with the behavior that it provides.
I’ve just posted preview 173 which should fix auto-name of documents, though the behavior is changed. Auto-naming only happens until the first time document is autosaved now.
After updating to 1.18.1 (173), I noticed that whenever I try to save a file to an iCloud Drive folder (created well before Bike has its own iCloud Drive folder), there is a good chance that the beachball will appear, forcing me to quit the app abruptly and resulting in the loss of the file’s content.
Since most of time I save my Bike files to that (old) iCloud Drive folder, I’m not sure if this issue also happens on the local drive. This issue occurs frequently in both macOS Sonoma 14.4 and 14.4.1.
Hum… I was afraid of touching iCloud by (by adding iCloud Drive folder) because bad things always happen when I say “iCloud”. Grrr. Few observations:
I wasn’t able to replicate the problem.
Then I updated to 14.1 and on restart Bike launched and I got long beachball
The beachball did eventually resolve (after 30 seconds or so) without me having to restart Bike
Now saving/etc seems to be working again without problem.
I’m still thinking about this and am not really sure what is going on. If anyone else has noticed problems, or has ideas, please post!
As far as I can remember, it usually happens when I try to save a new file, and today it happened again.
I haven’t tried to save files to Bike’s iCloud Folder many times, maybe less than five. I usually save files to a different iCloud folder that I created earlier.
