I notice that Bike is happy to open .bike
files containing XML comment lines like:
Marked Style: My Custom Style
Custom Processor: true
but comment lines of this kind understandably get discarded on save.
Does it look feasible (or desirable) to retain them (or even build UI access to them) ?
Marked 2, for example, can read and use (keyName : valueString)
lines in XML comments to enable per-document style and pre-processing settings.
(If this seems a long shot, or tricky in relation to Save As {TXT, OPML}
, then an alternative may be to set up custom Pandoc pipe-lines with the help of scripts)
