Was looking at my sessions spreadsheets, and I noticed the headers and actual data don’t have a line break between them.
I don’t know why that would have changed, or if that bugs always been there. The WriteRoom code is old making it difficult to fix/update. The problem only seems to happen for that first line. As a workaround I think you can just insert that newline manually when needed.
So if you manually at the line break, and then do another session, it’ll add the line break for subsequent sessions?
It doesn’t look as if that would be needed – each session just appends a line to an existing file, so the header fix would only be needed once in the life-cycle of any given .csv file.
That’s what I meant. Thank you!
