WriteRoom 4.0 (Preview 421)
Overview Mode. View ▸ Overview Mode adds options (headings, find matches, spelling, checkboxes) and now stays on until you exit with Esc or by pressing a new toggle button.
  • Added Intel Mac support
  • Added a Blinking cursor setting
  • Added a setting to turn off macOS Writing Tools
  • Added animated scrolling (Settings ▸ General ▸ Editor)
  • Added find patterns (⌃⌥⌘P) and regular expressions
  • Changed list commands to nest indented lines
More performance work for overview mode, but should make other things a bit faster too… hopefully didn’t make anything slower.
Apple Review has thrown a wrench in app “official” launch. Been “waiting for review” for the last week. Grrg.
Good release !
Just experimenting here with the support for regular expressions in Find and Replace – is there a syntax we can use for group replacement ? (I have tried, for example, $1 and \1).
Ah, no. But will add for next release.
I appreciate the addition of Intel Mac support which increases my range as I move between devices and locations.
