This should be quite noticeable when on battery at 60 FPS, less so at 120 FPS. WriteRoom’s drawing has always been very fast, but it’s drawing directly to textures on GPU and that requires different codepaths then standard cocoa and there was a bad interaction between NSScrollView frame scheduling and WriteRoom editor texture frame scheduling.
This looks great in Window, but in Fullscreen I noticed a new unpleasant choppyness. Could this be connected to the update here? M2 Air, 27.2., 60fps tested
The smooth scrolling works in windowed screen, but in fullscreen, the scrolling is a little, but very noticeable choppy. I tested some settings, heading numbers, sticky headings, etc – non of those changes it. What changes it indeed is heaving the settings panel open in before a fullscreen WR window. If you then scroll the WR fullscreen behind it, the scrolling is fluid again. Once you close the little settings window, it is choppy again, very curious.
Thanks for continuing to dig into this. I’m still trying to reliably reproduce it. Does theme seem to make a difference? What about spelling/grammar highlights?
It is indeed related to themes, sorry, I did test them yesterday and it seemed bad on everyone – but “System” is fine both on Light and Dark. I tested most other thing, grammar etc., this doesnt change it for me.
Bunch of small releases here, so just keeping them all in this thread. Mostly I’m going back and forth with Mac App Store review making tweaks and working in any small requests/bugs reported here that I can.
That should already be in WriteRoom 4. Shows in titlebar by default, but you can click on it (in titlebar) in in resulting pallet choose that it shows in editor. And once in editor you can drag it anywhere you want.
ah thank you I hadn’t noticed that! Great. (If I’m being super-picky I would like to get rid of the oval pill that surrounds it when I put it bottom centre…)
I don’t want to add another option for this at this point. Maybe after themes system is public (sometime after current release, probably a few months) ask again if you still care. I could probably fit it in there.
