So to the “count’s” config popover I’ve also added window settings that can be customized per window. It’s a lot of UI, but doing it this way allows the titlebar to stay simple. I tried many different symbols/positions for another menu, they all looked to subtract more then they added.
So that’s what’s up with this. Plus if you are looking at this UI too much you are probably wasting time, so I don’t want to make it that pleasant!
The settings themselves are not new. They have all also been available in the View menu for a while. And they provide the ability to override settings that you set in WriteRoom’s global settings window (at least most of them).
These override value are stored as part of the windows “restorable state”. So they are not saved as part of document, but also not lost, as long as you leave the window open when quitting WriteRoom. Once you click the window’s red close button, then they are lost.
Thanks. Are the slider limits for the DEC theme customization intentional? Seems like they can only shift between 2-3 fixed values, and 3 2 of them won’t go beyond the default point. Not complaining if that’s the case (I like default settings), but it might be confusing
For me those are continuous with no ticks/fixed values. They do update/apply on the main thread. If you have many docs open they will be a bit less smooth to drag… but I’m just testing 10 docs open here and slower, but not that slow.
Why do I need to deselect “Highlight Spelling Errors” in the Edit menu for every new document? I have “Correct spelling automatically” deselected in Settings—>Autocorrect; it is also turned off globally in my Mac’s Settings app.
Ah, good question. Turns out I had disabled that for myself in new document a long time ago with a preference key, but never added a UI for it. I’ll do that in next release.
