Opened TP3 (154) for the first time, dragged to top and attempted to resize. Window moves to lower portion of display and then you can resize.
Screen recording:
Screen recording:
Wow, that’s some weird behavior for sure. Unfortunately I can’t seem to reproduce it… I’m running it in my Guest user account, so that should be same as a fresh install. Can you try TaskPaper > Check for Updates to get version 156 and see if that fixes it? (that’s the version I was testing with).
I did a logout/login and the issue no longer occurs. With build 154. Thanks for looking at this.
