Some of my saved searches have moved to Archive. Is this a bug or something wrong with my syntax?
Version 3.2 (200)
Version 3.2 (200)
Maybe I manually put them there accidentally. I just manually moved them out of the Archive which seems to have fixed it.
Might be related to this bug:
Phil,
I have the same problem and can’t describe what happens at the first time it happens. Hopefully Jesse find an bug fix for this
Kind regards,
Dimitry
I’m delaying 3.2.1 and trying to get in a few more bug fixes before I release it. I’ve just fixed the “Pasting text at the end of a focused project is unreliable” bug described above for the next preview release. I’m not sure that it’s what’s causing your searches to show up at the end, but it’s a very likely candidate.
