As of now, when I paste a link and keep typing, my input becomes part of the URL. This always catches me off guard, because I’m typically pasting a complete URL that doesn’t need modification.
I always have to pause for a moment and do a little dance with the arrow keys to get out of this.
Wondering if this is intentional / if we could have an option to have the cursor fall after the link?
Version: 1.14 (152)
I think I agree and will investigate for next release.
This behavior is changed in the latest preview release:
This was supposed to be a quick bug release. Then I started adding some smaller features. Maybe it should really become 1.15… while I ponder please check it out and let me know how it works for you.
Added Shift-Return to insert row above
Added Outline > Expand/Collapse All by Level
Added “Links” setting panel to control row link opening
Added support for Control-N and Control-P in choice palette
Changed caret affinity to downstream after paste
Fixed where hiding window could also collapse rows
