Voice control
Hello. Is there anyway to make bike work with Apple voice control. I use voice control a lot because I learn to depend on dictation when I worked in hospitals. And it is far easier for me to talk then to type.
Thank you very much, aside from this one issue, which is very important to me, bike is a fabulous, outstanding and excellent, super speedy outliner, better than all others except for brainstormSW who’s genius programmers have long disappeared and which only works under windows.
Hi and sorry, but no I don’t think Bike can be made to support voice control currently. Much of the good and bad of Bike come from the fact that I have custom built the text editor part, it doesn’t use the system text component. This means I need to implement all the details myself, and haven’t got to voice control.
I don’t have a good idea of when I will get to it. I tried to do so with Bike 1, made some progress, but never actually got to the finish line. I’ll probably give it another try for Bike 2… but I’m currently working on more basic things at the moment in Bike 2 development.
Late to a follow-up here, but I’m curious why standard keyboard dictation works in Bike, but the dictation component of Voice Control does not. Even though I do not personally need the more advanced accessibility features of Voice Control, I use it over the standard keyboard dictation because of the custom vocabulary list. Is there any middle ground for Bike to support the dictation layer of voice control while you still work on the more advanced accessibility aspects?
