I have several tasks, that have tags with multiple values, for example
task 1 @priority(1,2)
task 2 @priority(2,3)
and there tags are shown in sidebar like this:
@priority
1,2
2,3
instead of:
@priority
1
2
3
Is it intended behaviour and if yes - what should I do so they appear as in latter example? I’ve tried to use same tag several times like “task 1 @priority(1) @priority(2)” and second tag is not recognized as tag.
I have the same issue still with the 2nd tag not being recognized - can this behavior be supported? My usecase is as follows:
– Speak to @people(James) about the roadmap after @people(Anna) has updated it
Without being able to do this I’d have to do something like the following
– Speak to James about the roadmap after Anna has updated it @people(James, Anna)
Which is quite repetitive and error prone
Thanks for the explanation. Was wondering if there could be some magic in the background that would take two separate tags values and join them behind the scenes
@priority(1) @priority(2) = @priority(1, 2)
Ps wouldn’t want to do it on a priority tag as that wouldn’t necessarily make sense, but rather 2x people tags as above.
