I just migrated Bike (and everything else) from my old Mac to a new one. When I start Bike I get a box that says “UUID Not Matched”. Not a critical problem just puzzling. Does anyone have a fix? Thanks
This error is coming from the Paddle license key system. I think if you go to Bike’s Preferences > License and then:
- Copy your existing license key
- Deactive your license
- Paste in that saved license key and Activate your license
It should go away.
worked - thanks
Thanks, this helped me.
