Bike use one shortcut to expand a row and another shortcut to collapse a row.
Instead a single shortcut could be used (such as CMD+. or CMD+0) that toggle expand/collapse.
I wonât change the current design, but you can create your own toggle command with AppleScript. I think this should do it:
if selection row is collapsed then
expand selection rows
else if selection row is expanded then
collapse selection rows
end if
end tell
Hereâs how to use Scripts:
Thanks for the tip!
Out of curiosity, why a âtoggle open/collapseâ is not a better/good UX/Design in your opinion? (if you donât have the time to answer, feel free to skip ;))
Perhaps instead of changing the current design, only adding a toggle menu and shortcut?
Regards
I donât have a lot of logic behind decision⌠but current design is what I âexpectâ from using other apps. For example in macOS Finder list view expand/collapse is done with separate arrow keys. Same with older outliners like OmniOutliner.
If most apps before Bike used a toggle I would happily use that instead, but few if any of them seem to.
I would rather people use a script if they want a toggle. Iâm always battling (and sometimes winning) to keep menuâs and short and clear looking as possible. In this case I donât think dedicating a new menu item to expand/collapse toggle is worthwhile since
Important Note: I never use the Command-0 and Command-9 shortcuts myself. Instead I always exit to outline mode and use left/right arrow to expand/collapse items. You might find that easier.
Essentially the same as the AppleScript above (just holds back when the row is a leaf) but I found that I was reaching for this today, while trying to get an outline right
"use strict";
const main = () => {
doc = Application("Bike")
.documents.at(0);
return either(
msg => msg
methodName => methodName
bindLR(
doc.exists()
? Right(doc.selectionRow)
: Left("No documents open in Bike.")
row => fmapLR(
k => (row[k](), k)
row.containsRows()
? Right(
row.expanded()
? "collapse"
: "expand"
: Left("Leaf row")
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
const bindLR = lr =>
// Bind operator for the Either option type.
// If lr has a Left value then lr unchanged,
// otherwise the function mf applied to the
// Right value in lr.
mf => "Left" in lr
? lr
: mf(lr.Right);
const either = fl =>
fr => e => "Left" in e
? fl(e.Left)
: fr(e.Right);
const fmapLR = f =>
e => "Left" in e
? e
: Right(f(e.Right));
// MAIN ---
See: Using Scripts - Bike
To test in Script Editor.app set the language selector at top left to JavaScript
rather than AppleScript
You can assign a Bike script to a keyboard shortcut using utilities like Keyboard Maestro and FastScripts.
Not sure if I am doing this quite right yet, but for a Bike 2.0 Preview build 229 !startup
extension, I tried this, which seems to work (these Bike 2 extensions are fast !)
(Binding expansion toggle to â8)
import { FoldOptions, OutlineEditor, Row } from 'bike/app'
function toggleExpandCommand(): boolean {
editor = bike.frontmostOutlineEditor,
row = editor?.selection?.row;
return (undefined === row) || (
expansionToggled('completely', editor, row)
function expansionToggled(option: FoldOptions, editor: OutlineEditor, row: Row): boolean {
return (undefined === row.firstChild) || (
// Effect
editor[
editor.isExpanded(row)
? "collapse"
: "expand"
]([row], option),
// Value
true
export async function activate() {
bike.commands.addCommands({
commands: {
'!startup:toggleExpandCommand': toggleExpandCommand
bike.keybindings.addKeybindings({
keymap: 'text-mode',
keybindings: {
"cmd-8": '!startup:toggleExpandCommand',
keymap: 'block-mode',
keybindings: {
