I’m brand new to Bike Outliner; really like it and will definitely purchase a subscription. However, I do have a question: I tested the text formatting shortcuts with Cmd+E, and think it is a great implementation but I noticed that Underline is missing as an option. This is unfortunate because in my work I use a lot of strikethrough/underline formatting to indicate new and deleted text.
I imagine this is a know limitation of the software or file formatting?
Thanks, and great work on the outliner! It is very elegant.
Perhaps worth distinguishing between structure and decoration here.
Bike defines a set of standard HTML text run attributes {em, strong, code, mark, s, a, base} and custom style sheets can map these onto particular decorations.
In decorative terms,
em is typically displayed with an italic style,
strong with bold,
mark with highlight.
u is not included in that set – it has an uncertain status these days – but customising a style-sheet would allow you to repurpose mark, for example, if your aim is specifically to see an underline text decoration (no longer the normal purpose of <u> tags in HTML).
(As you’ve discovered, the s attribute is displayed by default as strikethrough)
If your workflow moves bike drafts on for further processing in a system which expects to see <u> tags to indicate new text, then a command line filter like:
jaq --from xml --to xml 'walk(
if type == "object" and .t == "mark" then
.t = "u"
else
end
)' input.bike > output.html
