A while back, Jesse helped me figure out how to create two JavaScripts—one to move a project up and one to move a project down.
This allows me to organize the TaskPaper outline from the keyboard (triggering the scripts through Keyboard Maestro).
Although this started as a project to learn more about JavaScript, I have been using the completed scripts since then, and they have proven to be extremely useful.
Rather than keep them to myself, I felt that it was time to share them here on the forum. I hope that you find them useful. Enjoy!
Move a project ↓ in the TaskPaper outline:
function currentProject(entry) {
let each = entry;
while (each) {
if (isProject(each)) {
return each;
each = each.parent;
function isProject(entry) {
return entry.getAttribute('data-type') == 'project'
let outline = editor.outline
let currentItem = editor.selection.startItem
if (!currentItem) {
return
let project = currentProject(currentItem);
if (!project) {
return
let projectsAncestor = project.parent;
if (!projectsAncestor) {
return
let nextProject = project.nextSibling;
if (!nextProject) {
return
projectsAncestor.insertChildrenBefore(project, nextProject.nextSibling);
editor.moveSelectionToItems(currentItem)
Move a project ↑ in the TaskPaper outline:
let each = entry;
while (each) {
return each;
each = each.parent;
if (!currentItem) {
return
if (!project) {
return
return
let previousProject = project.previousSibling;
if(!previousProject || !isProject(previousProject)) {
return
projectsAncestor.insertChildrenBefore(project, previousProject);
