How can this Apple script, Bike document template, be modified to:
- Append the current date to the file name?
- Create the hierarchy shown in the attached screen capture?
Thank you. Stan
For the date part, you could derive a yyyy-mm-dd date string like this:
on run
text 1 thru 10 of taskPaperDateString(current date)
end run
-- taskPaperDateString :: Date -> String
on taskPaperDateString(dte)
set {d, t} to splitOn("T", dte as «class isot» as string)
d & space & text 1 thru 5 of t
end taskPaperDateString
-- splitOn :: String -> String -> [String]
on splitOn(pat, src)
set {dlm, my text item delimiters} to ¬
{my text item delimiters, pat}
set xs to text items of src
set my text item delimiters to dlm
return xs
end splitOn
And for your template, perhaps this kind of pattern:
on run
tell application "Bike"
set doc to front document
if exists doc then
tell doc
repeat with n in {1, 2, 3}
tell (make row with properties {name:"Project " & (n as string)})
make row with properties {name:"Research ideas"}
end tell
end repeat
end tell
else
"No document open in Bike"
end if
end tell
end run
PS you probably now that you can suppress the default welcome text with a Preferences setting.
Bike > Preferences > Document > New: (unchecking Show welcome text)
Or, if you want to define your template in terms of XML (which would allow, for example, for some formatted text):
on run
if exists doc then
tell doc
import from my xmlSample() as bike format
end tell
else
end if
end tell
end run
on xmlSample()
"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<html><head><meta charset=\"utf-8\"/></head><body><ul><li><p><strong>Project 1</strong></p><ul><li><p><em>Research ideas</em></p></li><li><p/></li></ul></li><li><p><strong>Project 2</strong></p><ul><li><p><em>Research ideas</em></p></li><li><p/></li></ul></li><li><p><strong>Project 3</strong></p><ul><li><p><em>Research ideas</em></p></li><li><p/></li></ul></li><li><p/></li></ul></body>\n</html>"
end xmlSample
Though that kind of approach may be simpler to manage in JavaScript:
"use strict";
const main = () => {
bike = Application("Bike"),
doc = bike.documents.at(0);
return doc.exists() ? (
doc.import({
as: "bike format"
) : "No documents open in Bike";
const xmlTemplate = () => `<?xml version="1.0" encoding="UTF-8"?>
<html>
<head>
<meta charset="utf-8"/>
</head>
<body>
<ul>
<li>
<ul>
<li>
</li>
<li>
<p/>
</li>
</ul>
</li>
<li>
<ul>
<li>
</li>
<li>
<p/>
</li>
</ul>
</li>
<li>
<ul>
<li>
</li>
<li>
<p/>
</li>
</ul>
</li>
<li>
<p/>
</li>
</ul>
</body>
</html>`;
@complexpoint @jessegrosjean
Thank you everyone for your help.
The pieces are coming together.
I’ll add this date solution form alastor933.
Another approach might be to automatically import the template pattern you want from an external file.
Not tested, but roughly this kind of thing:
use framework "Foundation"
use scripting additions
-- EDIT THESE TO SPECIFY NOTES FOLDER AND TEMPLATE TO IMPORT
property notesFolderPath : "~/Desktop"
property templateFileName : "researchTemplate.bike"
--------------------------- MAIN -------------------------
on run
dayNoteFoundOrCreated("ResearchNotes")
end run
-- dayNoteFoundOrCreated :: String -> IO document
on dayNoteFoundOrCreated(prefix)
tell (current date) as «class isot»
set dateString to text 1 thru 10 of (it as string)
end tell
set noteName to (prefix & dateString & ".bike")
set fpNotes to filePath(combine(notesFolderPath, noteName))
set fpTemplate to filePath(combine(notesFolderPath, templateFileName))
do shell script unlines({"touch " & fpNotes, "open " & fpNotes})
delay 0.2
set n to (count of (rows of doc where name is not ""))
if 0 = n then
if my doesFileExist(fpTemplate) then
set maybeXML to my readFile(fpTemplate)
if maybeXML starts with "<?xml" then
tell doc
import from maybeXML as bike format
"[" & its name & "](" & its URL & ")"
end tell
else
"No bike format document found in:" & ¬
linefeed & tab & fpTemplate
end if
else
"Template file not found at" & ¬
end if
end if
end tell
end dayNoteFoundOrCreated
------------------------- GENERIC ------------------------
-- combine (</>) :: FilePath -> FilePath -> FilePath
on combine(fp, fp1)
-- The concatenation of two filePath segments,
-- without omission or duplication of "/".
if "" = fp or "" = fp1 then
fp & fp1
else if "/" = item 1 of fp1 then
fp1
else if "/" = item -1 of fp then
fp & fp1
else
fp & "/" & fp1
end if
end combine
-- doesFileExist :: FilePath -> IO Bool
on doesFileExist(strPath)
set ca to current application
set oPath to (ca's NSString's stringWithString:strPath)'s ¬
stringByStandardizingPath
set {bln, int} to (ca's NSFileManager's defaultManager's ¬
fileExistsAtPath:oPath isDirectory:(reference))
bln and (1 ≠ int)
end doesFileExist
-- filePath :: String -> FilePath
on filePath(s)
((current application's ¬
NSString's stringWithString:s)'s ¬
stringByStandardizingPath()) as string
end filePath
-- readFile :: FilePath -> IO String
on readFile(strPath)
set e to reference
set {s, e} to (ca's NSString's ¬
stringWithContentsOfFile:((ca's NSString's ¬
stringByStandardizingPath) ¬
encoding:(ca's NSUTF8StringEncoding) |error|:(e))
if missing value is e then
s as string
else
(localizedDescription of e) as string
end if
end readFile
-- unlines :: [String] -> String
on unlines(xs)
-- A single string formed by the intercalation
-- of a list of strings with the newline character.
{my text item delimiters, linefeed}
set s to xs as text
s
end unlines
Assuming a .bike file like the unzipped version of this as the template:
researchTemplate.bike.zip (1.2 KB)
