I just installed the updated version 3.5. The update ignores the theme that I was using before. I thought that perhaps I should “reconfirm” that TP needs to use a theme, but in the File menu, apparently I have no option of choosing “Open Application Folder”. And I do not know where my theme.less file is.
Is it possible to recover the theme that I was using before the update?
TaskPaper now support easy switching between multiple stylesheets and using a separate stylesheet for printing. Because of this I’ve created a dedicated stylesheets folder to store the stylesheets. You can access it through Window > StyleSheet > Open StyleSheet Folder.
You can find your previous theme.less file in the parent to that folder. Move it into the stylesheets folder and it should work. I changed quite a few of the rules in the base stylesheet, so I decided not to automatically copy over 3.3 stylsheets, though they should mostly work. I think the only breaking change is that I renamed the display span stylesheet attribute to content.
