Downloaded and installed version 178.
Works fine so long as I don’t mess with the themes.
I put in the sample code from the web site and not only did TaskPaper crash, but it wouldn’t restart and show lists until I deleted all the theme additions.
Right now TaskPaper doesn’t isolate theme errors… so even the slightest syntax error seems to take down the entire app. Obviously I need to get that fixed. But in the meantime if you post the problematic theme I can probably spot the problem.
I thought all the ones in the guide were good, but I might be wrong on that. Would like to know where the problem is coming from so I can fix.
