I sometimes use tags within my notes, for which I use a smaller font size. The tags, on the other hand, always have the standard font size. In the theme file, is there a way to target tags in notes items only? I could not find a working approach.
The reason that you need to do this is because the default stylesheet specifically sets tag size (so they stay body text size even if headers are made larger). So the above just explicitly sets the tag size when within a note.
