The Delete keyboard shortcut cannot be set to cmd-k
Move to Project… moves the item to the bottom of the target Project. If the project is big, it is difficult to find the moved item. I prefer the previous behaviour from TP2 of moving to the top of the project (ideally, indented one level)
I think we actually ran into this earlier in the preview version, then I forgot about it and recreated the problem. I think the issue might be that I have the name “Delete” in bot the edit and items menu. I’ll try renaming the second to “Delete Items” and hope that removes the issue.
Actually see this article for a way to make it work:
With that workaround I think I might leave things as the are. Adding “Items” to that menu seems redundant since it’s already in the “Items” submenu. If I use
