Hey Jesse,
I’m again on the quest for the perfect - or serviceable - outliner with completable tasks app. But in TaskPaper 2 (fresh from the Mac App Store) I can’t seem to create entries that are Notes - them instantly act/look like Tasks. Have tried from menu, not typing a dash - no luck.
Cheers,
Bob
Can you share a screenshot of what you are seeing?
There isn’t a super strong distinction between notes and tasks or projects in TaskPaper. At the end of the day they are all just lines of text… formatting is the big difference: projects should be bold, tasks “normal” with a dash in front and notes 50% grey color. (this is all with the default theme).
Thanks for the video.
That’s actually how things are supposed to work. Those lines that you are typing are being recognized as notes because they are colored grey. I think you may have adjusted the default theme so that a bullet is drawn for notes. You can change that through system preferences, or try some of the other themes that will make notes looks different.
I hope that helps.
