I thought I could choose to save a file as .txt, but when I try to I get this message from the system:
" You cannot save this document with extension “.txt” at the end of the name. The required extension is “.taskpaper”." and an offer to use both extensions so the filename ends .txt.taskpaper.
Am I missing something? It’s been a while since I’ve used Taskpaper, so it’s possible I’ve forgotten how it worked. Is it an OS setting? is there a Taskpaper setting that’s hidden somewhere?
