Changes include:
- Added Window > Float on Top menu option
- Fixed email highlighter to recognize longer extensions such as
legal
- Fixed disable multiple range text selection since it’s not supported by TaskPaper’s model.
Please try it out and let me know if you see any problems.
Download
Jim
2
Float on Top works well in my brief tests.
This is now the latest released version.
The command palette shows behind the floating window for me. But I’m on Macos Big Sur on my old mac. Maybe it’s not an issue on Monterey.
+1 here on
- macOS 11.6.4 (20G417)
- TaskPaper Version 3.8.17 Preview (477)
(I don’t see the Command Palette if Window > Float on Top is checked)
Thanks, will try to get a fix out soon. Seems like our developer could have foreseen this issue!
@gustafekeberg I believe this is fixed in new preview release:
