TaskPaper 3.5.1 Preview (276)
Hope to make this a quick bug fix release. Let me know if I’ve broke anything while trying to fix stuff :slight_smile:
  • Fixed Bug in 2-Set Korean input method
  • Fixed Crash when editing stylesheet in VIM
  • Fixed Crash when archiving first visible item
  • Fixed Add checkmark to View > Show Sidebar when it’s visible
  • Fixed Item > Move to Project to insert item at start of project’s items
Issue Tracker
Download
I know this is trivial, but could we eventually have the evaporating cloud graphic back for when we delete an item? I rather like it, and it’s helpful confirmation.
Keyboard shortcut: in this version, I am unable to change the keyboard shortcut for Edit->Selection->Select Branch. I was able to do so in the previous 3.5 preview version.
Adding to issue list. I like it too, but it requires a private API hack to make it work. Still I’ll look to adding it back.
It seems to still work for me. I just changed “Select Branch” to Command-I and that worked OK. I did notice when testing that the first time I set the keyboard shortcut to Command-I it would only work if I did Shift-Command-I. (I had TaskPaper open when I made the change in defaults). But then when I restarted TaskPaper it worked correctly.
ah, it works when i restart TP. restart isn’t needed for the other shortcuts. strange.
