A script which:
- copies to the clipboard, and
- displays in a dialog
the sum of all numeric rows which are either:
- visible and descending from (i.e. indented under) the current row, or
- (if the selection is extended) in the set of selected rows.
Here, for example, the selection is not extended, and all descendant numeric lines are summed, with the sum copied to the clipboard:
whereas in this case, the selection is extended, so only the selected lines are summed:
"use strict";
ObjC.import("AppKit");
// SUM of the numeric rows in the extended selection
// OR
// (if the selection is not extended)
// Sum of all visible numeric rows descending
// from the current line.
// Copied to the clipboard, and displayed in a dialog.
// Rob Trew @2022
// Ver 0.02
// main :: IO ()
const main = () => {
bike = Application("Bike"),
doc = bike.documents.at(0);
return either(
alert("Sum of numbers in Bike")
compose(
alert("Copied to clipboard"),
copyText
doc.exists() ? Right(
Boolean(doc.selectedText()) ? (
selectedRowsForest(doc)
visibleSubTreeOfRow(
doc.selectionRow()
.reduce(treeSum, 0)
.toFixed(2)
) : Left("No document open in Bike.")
// ---------------------- BIKE -----------------------
// forestFromIndentedLines :: [(Int, String)] ->
// [Tree {text:String, body:Int}]
const forestFromIndentedLines = tuples => {
const go = xs =>
0 < xs.length ? (() => {
// First line and its sub-tree,
[depth, body] = xs[0],
[tree, rest] = span(x => depth < x[0])(
xs.slice(1)
return [
Node({
text: body,
level: depth
})(go(tree))
.concat(go(rest));
return go(tuples);
// selectedRowsForest :: Bike Doc -> IO [Tree String]
const selectedRowsForest = doc => {
// Forest of currently selected rows.
rows = doc.rows.where({
_and: [
{selected: true},
{_not: [{
return forestFromIndentedLines(
zip(
rows.level()
rows.name()
// treeSum :: (Float, {text::String}) -> Float
const treeSum = (a, tree) =>
// Float accumulator updated by any
// numeric node texts in the tree.
a + foldTree(
x => ns => ns.reduce(add, 0) + (
parseFloat(x.text, 10) || 0
)(tree);
// visibleSubTreeOfRow :: Bike Row -> IO Tree String
const visibleSubTreeOfRow = row => {
// Tree of the given row and all its
// visible descendants.
const go = r =>
Node(
{text: r.name()}
r.containsRows() ? (
r.rows.where({
visible: true
})().map(go)
return go(row);
const alert = title =>
s => {
const sa = Object.assign(
sa.activate(),
sa.displayDialog(s, {
withTitle: title,
buttons: ["OK"],
defaultButton: "OK"
s
const copyText = s => {
pb.clearContents,
pb.setStringForType(
$(s),
$.NSPasteboardTypeString
s
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
const Node = v =>
// more child trees.
xs => ({
type: "Node",
root: v,
nest: xs || []
const Tuple = a =>
// different types.
b => ({
type: "Tuple",
"0": a,
"1": b,
length: 2,
*[Symbol.iterator]() {
for (const k in this) {
if (!isNaN(k)) {
yield this[k];
// add (+) :: Num a => (a, a) -> a
const add = (a, b) =>
// Curried addition.
a + b;
const compose = (...fs) =>
fs.reduce(
(f, g) => x => f(g(x)),
x => x
const either = fl =>
fr => e => e.Left ? (
fl(e.Left)
) : fr(e.Right);
const foldTree = f => {
const go = tree => f(
root(tree)
nest(tree).map(go)
return go;
// nest :: Tree a -> [a]
const nest = tree => {
// Allowing for lazy (on-demand) evaluation.
// If the nest turns out to be a function –
// rather than a list – that function is applied
// here to the root, and returns a list.
const xs = tree.nest;
return "function" !== typeof xs ? (
xs
) : xs(root(tree));
// root :: Tree a -> a
const root = tree =>
// The value attached to a tree node.
tree.root;
// span :: (a -> Bool) -> [a] -> ([a], [a])
const span = p =>
// Longest prefix of xs consisting of elements which
// all satisfy p, tupled with the remainder of xs.
xs => {
const i = xs.findIndex(x => !p(x));
return -1 !== i ? (
Tuple(xs.slice(0, i))(
xs.slice(i)
) : Tuple(xs)([]);
// zip :: [a] -> [b] -> [(a, b)]
const zip = xs =>
// The paired members of xs and ys, up to
// the length of the shorter of the two lists.
ys => Array.from({
length: Math.min(xs.length, ys.length)
}, (_, i) => [xs[i], ys[i]]);
// MAIN ---
To test in Script Editor, set the language selector at top level to JavaScript (rather than AppleScript).
See: Using Scripts - Bike
PS make sure that you copy the whole of the JS source text behind the disclosure triangle above, right down to the last lines, which look like:
// MAIN ---
