I’m have this problem with stray notes. I regularly find notes or pieces of notes in my taskpaper file, orphaned from their parent task. I think they come from tasks that have been deleted or archived, but I’m not certain. Sometimes I am not able identify what task they belonged with. I have not been able to figure out what I’m doing that causes this, and therefore don’t know how to prevent it. Anyone else have this problem or have an idea of what I’m doing?
Sorry I’m not sure… I don’t know of any bugs that would cause this.
Do you use filtered/folded views often? I think when views are filtered folded you might be deleting a non hidden item, but the hidden children might not be selected… so they show up again after the filter is cleared.
Thanks, @jessegrosjean. That could be it. The behavior of “Delete Items” is not what I expected. It seems to delete a line. My expectation was that it would delete the item with its children, or at least with its notes.
Yes, @complexpoint, I understand the difference between the two examples. However, Delete Items treats them the same: it gives the same result when called on the first line in either example. This is not what I would have expected.
In the first example, I’d expect Delete Item to delete only “Groceries:” In the second example, I’d expect Delete Item to delete “Groceries:” and the three tasks underneath it.
“Delete Items” is equivalent to selecting the current line and then pressing delete.
Simple… except when an item has hidden children (ie it’s folded) then when you fully select the line those children are also considered to be selected… and so the children are also deleted.
So the rule is if you place cursor on an item that also has children and “Delete Items”
Only the item will be deleted if children are visible.
Children will also be deleted if children are folded.
