In the standard macOS spell checker panel there’s an option at the bottom of the window to select a specific language or use the default “Automatic by Language” option:
Is that an important and used setting by anyone here? I assume it is, since its in default spell checker, but I’m also curious about the specific scenarios where “Automatic by Language” isn’t sufficient.
Second, assuming it is important, where should that language setting state be stored? It it part of the current view or document? So for example if you have a document open and are viewing that same document with multiple windows… when the setting changes in one window should that change also effect the other window? Or on the other hand is would it be better to have one window checking in one language and another window checking in another language?
