Is there a way to change the amount of vertical space between projects, tasks and notes?
Thanks
Bob
Thanks
Bob
Yes, there are a few options:
line-height-multiple
paragraph-spacing-before
paragraph-spacing-after
Here’s an example of them all together (probably not what you want), but a good starting point for tests.
item[data-type=project] {
line-height-multiple: 3;
paragraph-spacing-before: 50;
paragraph-spacing-after: 10;
Generally line height effects the underlying line height, caret height, and selection rect height for that line. The paragraph space before/after add spacing before/after.
Thanks for the rapid response
Bob
