I’ve run into a little problem in longer TaskPaper documents, where if I hit Return, the spaces between other lines on the page get slightly bigger or smaller. It creates a weird optical effect where it looks like all the text on the screen is moving when I hit Return.
I have this problem on my 2013 iMac (that’s a pre-Retina model) but I don’t think I’ve run into the same problem on my 2016 Retina MacBook Pro. However, I don’t have a similar problem in any other text applications on the iMac, so I think it may be a problem in TaskPaper itself. I have tried uninstalling TaskPaper and all its associated files and folders, and reinstalling, but that didn’t stop it.
I’m wondering if I’m the only one this affects, and if there’s any way to fix it. Thanks.
