If you add an @ sign in a search label, it messes up the label and adds the search to the label.
In the end i don’t need the @ sign so no big deal.
I’m not quite sure that I follow, can you paste in an exact example of what you are trying to do?
Sorry for slow reply.
When you edit a saved search, put an @ sign in the Label field. I was trying to name my search with the @ sign – not needed, just for cosmetic.
When you do that it does not display in the sidebar correctly.
So lets say i wanted to Label my search @XYZ , in the sidebar instead it says “@XYZ @search(@XYZ)” incorrectly.
Thanks,
Rob.
