Is there some way to debug scripts as documented in the user guide (Creating Scripts · TaskPaper User's Guide) with the Setapp version?
Yes, I think it should work as described in user guide… though I just noticed that the example script on that page has a syntax error. Instead it needs to be:
debugger;
