Is there a way, through scripting, to select all items in a project? I have a Keyboard Maestro script that does stuff with a selection I’ve made manually in Taskpaper…so I am wondering if I can make that selection of all items in Project X as part of the macro too.
If the project is selected, then one approach might be to extend the selection to its whole subtree with an incantation like:
const seln = editor.selection.startItem;
editor.moveSelectionToItems(
seln,
undefined,
seln.lastDescendant
Tho a quick check reveals that we also need to supply the end point of the last item, to include it in the selection.
Adding that, and allowing for the possibility that the selected node might be a project descendant, rather than the project node itself, perhaps something like:
// isProject :: TP Item -> Bool
const isProject = node =>
'project' === node.getAttribute('data-type');
seln = editor.selection.startItem,
projectItem = isProject(seln)
? seln
: seln.ancestors.findLast(isProject);
return projectItem
const endItem = projectItem.lastDescendant || projectItem;
projectItem,
0,
endItem,
endItem.bodyString.length
(n => `Selected ${n} project rows.`)(
editor.selection.selectedItems.length
: "Cursor not in project.";
Full JS Example
"use strict";
// main :: IO ()
const main = () => {
const doc = Application("TaskPaper").documents.at(0);
return doc.exists()
? doc.evaluate({ script })
: "No documents open in TaskPaper.";
// ----------------- TASKPAPER CONTEXT -----------------
const script = (editor => {
? seln
return projectItem
// Effect,
projectItem,
0,
endItem,
// and string value.
.toString()
// MAIN ---
Or in the GUI, of course, if the project item is selected, then:
Edit > Selection > Select Branch
⌘⇧B
