My goal was to have projects in TaskPaper that had a priority tag and then to have a script that sorted the list by the priority.
Requirements:
- Set the priority tag based on the Pareto Principle found here
** The @priority tag is composed of two values, an effort, and a result.
** Effort is a number, 1-3, indicating the effort required to accomplish a task (higher = more effort)
** Result is a number, 1-3, indicating the resulting benefit (higher = more benefit)
** Priority is then set as @priority(effort/result) so that priority value = higher priority task (this is intuitive to me) - Sort all the tasks in each project according to priority
Solution:
I wrote two scripts to do this.
- The first one pops up a small dialog asking for a number for effort, and the second one for result. The script then inserts a @priority(effort/result) tag. I then attach this script to a hotkey in Alfred 3.
- The second script sorts each project (including nested projects) by priority.
These were my first scripts so they are likely poorly written. But they are well documented and perfect for newbie consumption since I had no clue what I was doing and so make them as easy to read and digest as possible. Please enjoy. And if anyone has improvements PLEASE do share!!
As a sidenote, I’ve written a couple of Alfred 3 workflows to quickly add tasks to the “inbox” of my taskpaper files and could share if anyone is interested.
Script to set priority:
(function () {
// JavaScript for the Automation context
var min = 1;
var max = 4;
var default_val = 2;
// get the application TaskPaper
TP = Application("TaskPaper");
// get the standard additions which allow dialogs and other interactions with the system
// if you don't want TP to be the focused app, use Application.currentApplication() and set
// the standard additions to true in that app.
TP.includeStandardAdditions = true;
// note that JXA syntax is just weird, requiring the first parameter like normal, and
// subsequent parameters to be in curly braces with the name of the parameter a colon, then the variable, then a comma. Seems silly to me.
// get the effort required
var effort = TP.displayDialog('Set Effort...('+min+'-'+max+')',{
withTitle: 'Set Effort for Task',
defaultAnswer: default_val,
buttons: ['OK','Cancel'],
defaultButton: 'OK',
cancelButton: 'Cancel'
// convert to a number
effort = Number(effort.textReturned);
// check to see if input was valid
if(effort < min || effort > max) {
return;
// get the result
var result = TP.displayDialog('Set Result...('+min+'-'+max+')',{
withTitle: 'Set Result for Task',
result = Number(result.textReturned);
if(result < min || result > max) {
return;
// calculate the priority
var priority = (effort/result).toFixed(1);
// get the priority
var priority = options;
// sets the attribute
function setAttribute(editor, items, name, value) {
var outline = editor.outline;
items.forEach(function (each) {
each.setAttribute(name, value);
// pass to setAttribute the editor, the selectedItems
setAttribute(editor, editor.selection.selectedItems, 'data-priority', priority);
// call the JavaScript
script: TaskPaperContextScript.toString(),
withOptions: priority
Sorting Script:
// group all the changes together into a single change and make it a single "undo" action
// all the projects
var projects_array = outline.evaluateItemPath('@type=project except archive:');
// for each project get the tasks with priority
projects_array.forEach(function(each) {
var has_children = each.hasChildren;
if(!has_children) {
return;
var children = each.children;
// handle the case of only one item in a project
if(children.length < 2) {
return;
children.sort(function (a, b) {
// a and b are elements of the array
// get the priority value of task a, "getAttribute" takes the attribute name,
// and whether or not the value should be converted to something else (in
// this case a number)
//debugger;
var a_priority = a.getAttribute('data-priority', Number);
var b_priority = b.getAttribute('data-priority', Number);
//var a_has_done = a.hasAttribute('data-done');
//var b_has_done = b.hasAttribute('data-done');
// need to return negative, zero, or positive
// negative indicates a < b
// zero indicates a = b
// positive indicates a > b
// Here null means the item didn't have a priority tag
// In this case b < a
if(a_priority == null && b_priority != null) {
return 1 ;
} // In this case a < b
else if (a_priority != null && b_priority == null) {
return -1;
} // In thise case a = b
else if (a_priority == null && b_priority == null) {
return 0;
} // In thise return a relative to b
else {
return a_priority - b_priority;
}); // end sort
each.removeChildren(each.children);
each.appendChildren(children);
}); // end projects_array.forEach
}); // end outline.groupUndoAndChanges
} // end TaskPaperContextScript
var string = Application("TaskPaper").documents[0].evaluate({
; but I am also thinking to delegate this to someone who is a computer newb. Now, if you need to see some of my source files, so that everything is accomplished in JavaScript/Bash instead of Ruby/Bash I would gladly provide them. Like I said again, they are just simple modifications to the library Matt contributed.
