For scripted operations like:
- Copy as MD (or some other format),
- export visible lines to
.docx
etc
It might be useful, at some point, to have scripted access to the HTML for the whole document, and particularly for the visible (focused, unfolded) subdocument.
(the existing row.htmlContent
is excellent for inline formatting, but doesn’t include the nesting of rows)
We can already get:
- document HTML through the file system, and
- HTML for the visible part of document via the clipboard (select all, copy,
com.hogbaysoftware.bike.xml
pasteboard item)
but in due course, if it looked feasible, direct script property access to document (and document section) HTML would allow for less screen flicker during a script run : )
