Anybody have a script they’d recommend to toggle between two font sizes?
- “Actual Size” for most times, and a
- “Screen sharing” font size that’s 4 or 5 font sizes bigger?
Perhaps two stylesheets with different names under Window > StyleSheet
(it would then be fairly straightforward to write something like a Keyboard Maestro macro which toggled the stylesheet selected)
Here, for example, toggling between Default.less
⇄ ScreenShare.less
in which the only differing line is:
font-size: @user-font-size
⇄ font-size: (@user-font-size * 4);
Hey @complexpoint, you’re right, I had forgotten about the separate style sheet trick, which I even had done in the past! Thanks for the reminder.
